April 12, 2024 at 1:31 pm
omar.ennaya
SubscriberHello everyone
I have a problem on how to enter two values of the material density and to fix the boussinesq option in the same time.
I utilised the boussinesq option and choose the oprating density at Tm but when i verify the variation of the density with time i found it still constant.
I should enter the density value of the solid phase and the liquid.
please help with this, i'm stuck.
April 12, 2024 at 2:03 pm
Forum ModeratorYou can't. A fluid density can be set using the Bousinesq option, and that's covered in the User's Guide. However, the solidification/melting model doesn't have an option to change the fluid density when it freezes; that's done via the material property, which then prevents you using the Bousinesq option.Â
April 12, 2024 at 3:08 pm
omar.ennaya
SubscriberYes this is what i thought, it's just my supervisor he insiste that should make it cuz it's possible.thank you for the feedback.
- The topic ‘how to input two values of the density in fluent’ is closed to new replies.
6029
