July 12, 2023 at 7:20 pm
Shivesh Sharma
SubscriberI am using ANSYS 2023 R1 and running a simulation based on an experiment. The input for velocity and turbulence intensity is based on a power law profile. I can enter the velocity as an expression, but when I try to do the same for turbulent intensity, I get an error that says ‘expression is not single-valued.’ I have also tried to input this expression as a new parameter, but it still gives the same error. Can anyone help me solve this problem?
July 13, 2023 at 3:42 am
Essence
Ansys EmployeeHello,
Try using abs(y) instead of only y in the expression.
July 13, 2023 at 8:28 pm
July 14, 2023 at 9:11 am
Essence
You are getting this error because the present expression needs to evaluate to a single valued constant. If it is not a constant you will get the error you are seeing.Â
July 17, 2023 at 5:01 pm
Shivesh Sharma
SubscriberHi,
I'm inputting the turbulent intensity as an expression because it varies with height. If I were to use a single valued constant, the turbulent intensity would not change with height, which means I wouldn't need to use an expression. -
July 18, 2023 at 9:27 am
Essence
I hope this Forum discussion will help you. Please refer the Forum thread:
/forum/forums/topic/turbulence-intensity-expression-inlet-outlet/
July 18, 2023 at 2:22 pm
Shivesh Sharma
SubscriberThank youÂ
- The topic ‘How to input Turbulent Intensity as expression’ is closed to new replies.
5899
1306
