June 1, 2024 at 7:17 am
Adamya Dhaker
SubscriberHello! I have a hyperelastic, deformable body. I obtain the body's deformation by applying certain forces, and then I want to obtain the same deformation by using the displacement of the body (its centerline/contours etc.) as an input. I have attached a photo showing snapshots of its motion across time (top:t=0, bottom=t=T)
How can I use displacement data as an input to get the same motion? For example, I have the coordinates of the centerline across time as the body deforms- can that be used as the input? If yes, then how so? Or is there any other way to use displacement input to get the deformation?
Many thanks in advance :) -
June 4, 2024 at 10:31 am
Kaushal Vadnere
Ansys EmployeeÂ
Hi Adamya,
You can calculate the displacement of the face on which you have applied force by using directional deformation results in X, Y, Z direction and then in a new system, you can input those values as displacement boundary condition. See below:
Here, I quickly setup a simple cantilever beam model and applied a force of 10N in Z direction. I got -0.1592mm directional deformation in Z direction. Equivalent Von-Mises Stress is 26.61 MPa.
I took the -0.1592mm directional deformation, and applied that as displacement boundary condition to the face (For your model, you may have to consider all three X, Y & Z directional deformations).
After solution, you can see in the 2nd screenshot, the Equivalent Von-Mises Stress is almost same and force reaction is also 10N.Â
Also, your model has multi-step analysis, so take directional deformation at all the time steps and apply displacement in same no of steps.Â
- The topic ‘How to input displacement to obtain deformation and motion in a body’ is closed to new replies.
