How to Incorporate Negative Axial Stiffness in a Radial Magnetic Bearing for
    • supreeth.k
      I'm working on a radial magnetic bearing model for modal analysis in ANSYS Workbench. I need to introduce negative axial stiffness into the bearing's behavior. What is the recommended approach to achieve this—either directly through the built-in connection settings or by using custom APDL commands (such as with COMBIN14 or MATRIX27)? Any insights or best practices would be appreciated.
      Thanks!
    • dlooman
      COMBIN14 would be the simplest way for a modal.  A nonlinear negative stiffness is possible with the transducer element, TRANS126, since electrostatic attraction increases as the gap closes.
    • supreeth.k
      Thanks for the suggestion! Could you guide me on how to properly implement COMBIN14 for negative axial stiffness in my modal analysis? Specifically:
      1. How do I extract nodes from a face selection where the bearing is located?
      2. How should I assign a negative axial stiffness to the COMBIN14 element?
      3. At what stage should I apply this APDL code to ensure it correctly affects the modal analysis?
      Any detailed steps or example APDL commands would be really helpful. Thanks in advance!
    • dlooman
      Like you would create any spring in the gui.  Use the Direct with a negative stiffness element.
    • supreeth.k
      Thank you for your help
Viewing 4 reply threads
