October 23, 2021 at 2:29 am
sui sui
SubscriberDear friends, first of all, I must say that SpaceClaim is the most perfect design software known on the planet, thank you for your hard work on this, in the attached video, the design file created is about 196MB, in order not to affect the performance, only a very small number of assembly commands were used, it seems difficult to continue with, especially when sketching lag is obvious, but at the same time, the CPU and GPU are idle, they are not fully engaged in the work, I do not know, increase the CPU main frequency or increase the number of cores, which is more useful, if necessary, I can upload the file for study, thank you.
With all due respect -
October 25, 2021 at 5:17 am
Devendra Badgujar
Forum ModeratorHi sui sui
Let me check and will get back to you.
Till then can you please share the file for which you get the said issue so that I can replicate it on my end to understand it better.
Regards.
October 25, 2021 at 5:58 am
October 25, 2021 at 6:47 am
Devendra Badgujar
I have sent you the secure transfer link via email. Please can you share the files through that.
Regards.
October 25, 2021 at 7:44 am
sui sui
SubscriberOK, the transfer was successful, thanks.
Best wishes. -
October 25, 2021 at 12:58 pm
Devendra Badgujar
I have not received the files yet, have you shared them ?
October 25, 2021 at 3:15 pm
October 26, 2021 at 5:48 am
Devendra Badgujar
The files that you sent via mail are not opening, please can you again send the files via secure transfer link.
Regards.
October 26, 2021 at 6:11 am
October 26, 2021 at 8:40 am
Devendra Badgujar
Forum Moderatorsui sui
Thank you, I have received the files. I will check and get back to you.
October 26, 2021 at 8:36 am
October 27, 2021 at 6:30 am
Devendra Badgujar
Was the design created in SpaceClaim or it was imported from other design software ?
I checked your design and it has geometry errors in it and generally they occur if the file is imported from other software. I have seen many times that these types of errors impact the performance of SpaceClaim.
Regards.
October 27, 2021 at 6:56 am
sui sui
SubscriberThank you for the reminder that the main parts are created by SpaceClaim, there is a part that does not support expansion is imported stp format file, followed by standard and generic parts for external import, creating this process with SpaceClaim is important, I think that
Thank you again -
October 27, 2021 at 7:39 am
sui sui
Subscriber是的,正如你所说,几乎所有的错误都在导入实体中,我忽略了几何错误的概念,为我的错误道歉,我会开始研究它们,祝你
万事如意 -
October 27, 2021 at 8:55 am
sui sui
Subscriber几何错误已经得到处理,但是!!!
October 27, 2021 at 8:56 am
sui sui
SubscriberThe geometry error has been taken care of, but!!!
October 27, 2021 at 9:49 am
Devendra Badgujar
Are you still facing performance issues after removing geometry errors?
October 27, 2021 at 10:09 am
sui sui
SubscriberDear friend, my initial intention was to give some feedback on some clues to make SpaceClaim more perfect, you and your team are great,.
Best regards. -
October 28, 2021 at 6:41 am
Roberto
SubscriberHello Devendra Badgujar
It would be great if spaceclaim didn't slow down too much by importing geometries from different files, it would also be very useful if it imported geometries with fewer errors
Regards
- The topic ‘How to improve performance’ is closed to new replies.
5899
1306
