February 9, 2022 at 7:10 am
sadhurajesh
Subscriber1.geometry
February 9, 2022 at 9:43 amKeyur Kanade
Ansys EmployeePlease check following videos
Ansys Meshing: Decomposition for hex meshing:
https://www.youtube.com/watch?v=P19GOTQWmc0
Ansys Meshing: Meshing Methods:
https://www.youtube.com/watch?v=nEOC8rDnnRo
First check the locations of the bad elements. Please see following video for the same.
https://www.youtube.com/watch?v=ZDADSSN8hOs
Once you have locations, please check if you can improve mesh using different mesh sizing. Please see following video.
https://www.youtube.com/watch?v=w4q6q8nKF3U
If this does not help, you may need to check if you can use pinch control or virtual topology.
https://www.youtube.com/watch?v=wdKMqfJV1Ys
https://www.youtube.com/watch?v=RELLrEJ9chg
If this does not help, please go to geometry and modify or simplify geometry at those locations in SpaceClaim.
Regards Keyur
February 17, 2022 at 3:54 amFebruary 17, 2022 at 12:04 pmKeyur Kanade
Ansys EmployeeAre you using multizone.
Please check tutorials on multizone. It would be better to split the geometry.
Regards Keyur
February 18, 2022 at 10:01 amsadhurajesh
Subscriberhow to split the geometry?
February 18, 2022 at 11:39 amRob
Forum ModeratorI tend to favour the Split command: have a look at the geometry tutorials.
February 18, 2022 at 12:35 pmsadhurajesh
Subscriberwhere to where we have to split the body to get hex meshing
February 18, 2022 at 1:38 pmRob
Forum ModeratorIf you want a hex mesh you'll either need logical cubes (not something I'd try) or sweep. Personally, I'd be looking at Fluent Meshing and just poly the whole thing. How are you getting on with the tutorials?
February 19, 2022 at 5:22 amsadhurajesh
SubscriberAnsys Meshing: Decomposition for hex meshing:
https://www.youtube.com/watch?v=P19GOTQWmc0 I am unable to understand
February 21, 2022 at 11:57 amRob
Forum ModeratorWhich bit?
March 3, 2022 at 7:05 amMarch 3, 2022 at 11:50 amRob
Forum ModeratorI'm assuming you checked the cell skew? What is causing the blocks to distort like that?
March 3, 2022 at 1:12 pmsadhurajesh
Subscriberskewness - min 1.3057e-010, avg 6.0265e-002, max 0.97917
aspect ratio- min1.0002, max 82.067
orthogonal quality- min 2.0831e-002, max 1, avg 0.94992
element quality- min 3.6629e-003, max 1, avg 0.72873
these are the mesh quaities. how to improve skewness
March 3, 2022 at 1:54 pmRob
Forum ModeratorBy understanding why the skew cells are created: why are they getting squashed in the image?
March 7, 2022 at 10:24 amsadhurajesh
Subscriberafter meshing they squashed
March 7, 2022 at 3:29 pmRob
Forum ModeratorLook carefully, and use cut planes (show full cells) to see what's going on. Please post those images so I can see what's going on.
March 8, 2022 at 5:10 amMarch 8, 2022 at 9:15 amMarch 8, 2022 at 11:36 amRob
Forum ModeratorClick on the blue tetrahedron in the cut plane panel, that shows the full cells. However, I think your problem is that you've meshed the thickness of the baffles: the jump in cell size is then huge which isn't going to result in a stable run. You also want at least 6 cells between the plates to get anywhere near sufficient resolution to pick up the velocity profile.
Viewing 18 reply threads- The topic ‘how to improve mesh?’ is closed to new replies.
5654
1890
1404
1303
