May 4, 2024 at 3:38 am
Bibekananda Nath
SubscriberI need to determine the efficiency of a solar cell using a random blackbody spectrum rather than sun. In order to do that I need to determine the solar generation rate for a random blackbody source rather than sun. But how can I insert the blackbody source's power spectrum inside the 'analysis' script of the solar generation analysis group?? Please help me in ths regard.Â
May 6, 2024 at 5:07 pm
Guilin Sun
Ansys EmployeeIn such case, the simulation source settings are the same.
In the analysis group, you will need to load/read the desired source data, and replace the solar spectrum. The rest is the same. I suggest to use matlabload:
- The topic ‘How to Import Random Spectrum instead of AM1.5G Spectrum in Solar Genaration’ is closed to new replies.
1495
1386
1209
