January 16, 2021 at 11:29 am
Abdulsalam
SubscriberHello everyone!
I am currently working in a project that can be only preformed in Ansys APDL . So Any idea that can help me to import my geometry only without even the mesh to Ansys APDL, then in APDL I set up the model for solving and analysis. I tried to use the Write Input File command and I faced the following issues:
1- When I open the geometry in APDL it only shows the nodes only.
2- The file I opened it appears with a generated mesh which I don't want.
3- I used the Commands ALLS and EPLOT to show my geometry Area but in APDL It says there is no area Identified.
I need Only the WB Mechanical to create the FEM, then port it over to MAPDL to set up the model for solving. I have attached the relevant photos of my problem.
Any help Will be much appreciated.
January 18, 2021 at 11:38 amAshish Khemka
Forum ModeratornnYou can export the geometry from SpaceClaim ( as .iges file) ad then import the same. For importing the geometry in APDL please see the steps below:nnnRegards,nAshish KhemkanJanuary 19, 2021 at 3:20 amAbdulsalam
SubscriberDear nThank you for your replay!. from the PDF file you sheared Some of the options I can't find them in my MAPDL (Student version) it Semmes that the steps in the PDF file is available in the licensed version of ANSYS.Best Wishes, nAbdulsalam nFebruary 7, 2021 at 4:37 pmAbdulsalam
SubscriberHi!nThe problem is solved for anyone still wondering how to import the geometry from workbench to MAPDL. See the post below nHi @Aniket It works also! thank you so much Regards, Abdulsalam/forum/discussion/comment/103767#Comment_103767
n Regards, nAbdulsalam nViewing 3 reply threads- The topic ‘How to Import a Geometry from Workbench to APDL?’ is closed to new replies.
5989
1307
