February 23, 2022 at 1:39 pm
mandeep_shetty
SubscriberHello,
We are using Spaceclaim 18.2. I had imported surfaces (which encloses a volume but 'solid' wasn't created just yet) in iges format. I created solids from these surfaces in SpaceClaim. Creating the solid removed all the surfaces from the structure tree and put all the surfaces into a solid as expected. Now when I select any of the face that make up the solid and try to hide it, the whole solid gets hidden instead of just the selected face. I want to hide few external faces so I can create name selections from some of the internal faces. So how to hide only selected faces?
February 23, 2022 at 4:29 pmRahul Kumbhar
Ansys EmployeeHave you been selecting the face, then right click to select 'Hide' option? Id so this will hide the body. You should following option, select face>>right click>>'Face'>>Hide Face
February 23, 2022 at 7:20 pmmandeep_shetty
SubscriberThank you. Yes when I had used Spaceclaim 19 I had done the same. But I am not able to fine the 'face' option when I right click after selecting the appropriate faces in version 18.2. I see only 'hide' and 'hide others' option.
February 24, 2022 at 2:54 ammandeep_shetty
SubscriberFound this after a lot of searching! /forum/discussion/19701/spaceclaim-18-1
Viewing 3 reply threads- The topic ‘How to hide selected faces in spaceclaim’ is closed to new replies.
Innovation SpaceTrending discussions- Project lines/edges into a face with the direction normal to the face
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
Top Contributors-
4042
1461
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
