April 19, 2019 at 9:47 am
Minki
SubscriberHello, I want to get view factor matrix of annealing furnace,
but I cannot find the way to get view factor matrix in ANSYS tool.
I want to know what toolbox I have to use and how can I use that toolbox.
April 23, 2019 at 10:46 am
Forum ModeratorThe S2S model in Fluent uses a view factor approach. This is also saved as a file so we only need to calculate it once (assuming nothing is moving!). Not sure how readable that file is outside of Fluent though.Â
April 25, 2019 at 8:08 am
Minki
SubscriberI can find the way to print view factors on console on Fluent tool at the postprocessing tab->Model Specific->S2S Information.
However, that wasn't work good. I made an example of tow parallel cube, and tried to get view factor between two face-to-face surface.
The view factor I gotten was zero. I think that is not reasonable value. It seems to be a near to one.
What's wrong in my example?
April 26, 2019 at 10:05 am
Forum ModeratorCheck the two volumes are connected & there isn't a wall in the way: did you do share topology (SpaceClaim) or multibody part (DesignModeler)?
April 26, 2019 at 10:43 am
Minki
SubscriberThanks for your answer,
In my example, the two volumes are not connected.
There are nothing between volumes, but I thought that the empty space is regarded automatically as air.(Is it right?)
However, it does not seem like that.
Then, how can I model in SpaceClaim to caculate View factors of separated faces? There will be nothing(just air) between faces.
April 26, 2019 at 2:09 pm
Forum ModeratorNo, if it's not meshed in Fluent it doesn't exist: you need to have mesh between the two (or more) faces. If you want to calculate the factors you need to include the geometry in a larger volume, mesh that & pass to Fluent.Â
- The topic ‘How to get View factor matrix using ANSYS’ is closed to new replies.
- affinity not set
3977
1461
1272
1124
