April 25, 2022 at 4:19 am
13121231192
SubscriberEach structure of Geometry seems to be able to select only one specific material, so how to combine the two materials into one object?  For example, if I want to design a hafnium oxide/aluminum oxide laminated (HAOL) gate dielectric, how can the electrical parameters of these two materials be simultaneously assigned to a structure? Â
April 25, 2022 at 10:40 pmkghaffari
Ansys EmployeeHi,
Could you please elaborate on how this feature would be helpful? At each point in the simulation region only a single value for a material property is used by the solver. So you should be able to account for that with one of the two materials (and objects) or an object with a new effective material property (which will be user input).
Viewing 1 reply thread- The topic ‘How to get two different materials in the same structure in Lumerical?’ is closed to new replies.
