December 6, 2023 at 2:54 am
December 6, 2023 at 7:50 am
Afroditi Petropoulou
Ansys EmployeeDear Saurav,
To get the transmission you can use the transmission command:
T_avg=transmission("monitor_2");
or you can use the following:
T_avg=getresult("monitor_2","T");
?T_avg.T;
Best Regards
Afroditi
December 6, 2023 at 7:55 am
Dimitris Polyzos
Ansys EmployeeHello,Â
Thank you for contacting us. It would be helpful if you could provide a little bit more information regarding your model. However, I believe that you should use 2D monitor in your simulation to get a dataset of transmission similar to the picture below:
I hope I helped. Please let me know if you need further assistance.
Kind regards
Dimitris
- The topic ‘how to get transmission value using script’ is closed to new replies.
1487
1318
1157
