January 18, 2022 at 7:39 am
sahilrafiqbht
SubscriberI have obtained the mesh of enclosure with face split but how to get the same mesh as attached in photo.
I'm not able to get the circle passing from mesh intersection and get the same in setup.
Please help
January 18, 2022 at 11:36 amKeyur Kanade
Ansys EmployeeIt looks like the mesh is from ICEMCFD or some other tool. The circular curve is not part of the mesh. It is just display.
Please go through help manual for more details
Regards Keyur
January 18, 2022 at 1:32 pmsahilrafiqbht
Understood
Thankyou for your reply.
Is there any way I can get the same mesh than with a hollow triangle in centre.
While I'm trying to get that as you can see along the sides there is inclination.
I'm trying to get the best possible staggered mesh consisting of quadrilaterals only.
Please let me know if it's possible in this case
January 18, 2022 at 1:50 pmRob
Forum ModeratorYou've got a hex (quad) mesh. What are you aiming for?
January 18, 2022 at 1:55 pmsahilrafiqbht
SubscriberAs you can see along the altitude of triangle the mesh to the sides of traingle is oblique I'm trying to get it same as obtained above and below ie straight lines only i don't want any oblique lines.
January 18, 2022 at 2:22 pmRob
Forum ModeratorAround a triangle? Why would you want to do that?
January 18, 2022 at 2:56 pmsahilrafiqbht
SubscriberThanks for replying but i think I'll work it out
January 18, 2022 at 5:12 pmRob
Forum ModeratorIf you manage it please post the results & method.
Viewing 7 reply threads- The topic ‘How to get this mesh’ is closed to new replies.
