August 22, 2025 at 1:27 am
August 22, 2025 at 8:16 am
Forum ModeratorMost of the materials are set as you've found and then used in a mixed form in the cells. The various cell values can be found in the documentation.Â
August 22, 2025 at 2:28 pm
Mark O
Ansys EmployeeThere is no documented access to the material property routines. The simplest thing is to change the specific heat property to a user defined property that calls a function to evaluate the specific heat as a function of temperature. Then you can call the same function anywhere else in the code where you need it.
Ansys Innovation Space
1333
1168
1090
1014
