July 13, 2021 at 2:20 am
Awlad
SubscriberDear Support Engineers:
I am using ANSYS Mechanical APDL. I am doing a static structural analysis of a simple truss, as shown below. This truss has 3 nodes and 3 elements. I am using LINK180 with 3 DOF per node. So, the size of the stiffness matrix [K] will be (9x9).
July 13, 2021 at 5:39 am1shan
Ansys EmployeeYou can use the commands *DMAT and *SMAT to get the stiffness matrix. Also check this blog - https://www.padtinc.com/blog/apdl-math-access-to-the-ansys-solver-matrices-with-apdl/.
Regards Ishan.
July 13, 2021 at 5:47 pmAwlad
SubscriberDear Mr. Ishan:
Is there any ANSYS Verification Model that I could also study besides checking the blog that you suggested? That will be very helpful too. Many thanks Awlad.
July 14, 2021 at 4:30 amAwlad
SubscriberDear Dr. Ishan:
APDL is very powerful. However, it is bit difficult to learn as it is based on Commands and Syntax. Hence, I wish to get an input file to learn how to use the *DMAT command with full understanding. Please help me if your capacity permits. Thanks Awlad.
July 14, 2021 at 8:08 am1shan
Ansys EmployeeANSYS employees cant share files however https://www.youtube.com/watch?v=C1CIfrs9_KY is a good video you can follow. Also whenever you comment and want to mention someone use '@' before the name. This way that person is notified.
Regards Ishan.
July 14, 2021 at 8:14 amErik Kostson
Try also to search on the internet for say: *DMAT and truss and ansys, and there will be some good tutorials you can follow.
Thank you
Erik
July 14, 2021 at 7:00 pmAwlad
SubscriberDear Many, many thanks for sharing the YouTube link. The "*DMAT" command should be under "/solution" branch in Mechanical APDL. Is my understanding correct? Thanks again Awlad.
Viewing 6 reply threads- The topic ‘How to Get Stiffness Matrix as an Output?’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4092
1487
1318
1156
