September 17, 2019 at 5:11 pm
vidyadhar.kpm
SubscriberHello,
The interface in my VOF simulation involving liquid-vapor appears to be spread over three to four cells.
The simulation is converging as the residuals fell below default settings and the area of the interface has become constant with further iterations/timesteps.
The fluid properties of both liquid and vapor are the same. Vapor lying above liquid. Gravity is considered.
I am using PISO/LeastSquareCell/SecondOrder/GeoReconstruct/Warped-FaceGradientCorrection/HigherOrderTimeRelaxation; Explicit VOF formulation with implicitBodyForce; and A timeStep of 1e-06 s. Mesh is 3D unstructured - tetrahedrons
I want the interface( 0
To achieve it, I tried the following:
1) Refining the mesh in Workbench and running new simulations. Though I achieve convergence, the interface is not sharp
2) Adapting the mesh in Fluent. As soon as I adapt the mesh using GradientAdaptation, I am not achieving convergence even with lower timesteps and the interface appears wavy.
I request help on how to get a sharp interface, i.e., the region 0
Thanks & Regards,
Vidyadhar
September 25, 2023 at 8:12 am
l yx
SubscriberI have encountered the same problem. Have you solved it??
September 25, 2023 at 2:52 pm
Forum ModeratorVOF and evaporation may not work well. Typically you'll see a few cells with volume fraction 0.25 < value < 0.75 due to a mix of convergence and model set up. Without knowing what the rest of the set up is it's difficult to comment.Â
- The topic ‘How to get Sharp Interface in VOF simulation?’ is closed to new replies.
