How to get inelastic strain energy accumulated per cycle for postprocessing in ANSYS student edition
October 10, 2021 at 8:57 am
Andrew_tan
SubscriberIs it available by default? If yes, where is it located? If no, is it available to be installed from somewhere?
October 15, 2021 at 6:02 pmSean Harvey
You can use get the plastic strain energy density using a user defined result in solution. Right click, insert, user defined result. For expression you will enter nlplwk. Keep in mind this is strain energy density contoured on an integration point basis.
Keep in mind that in Analysis Settings Output controls, you need nonlinear data set to yes.
Let us know if this helps.
Regards Sean
Viewing 1 reply thread- The topic ‘How to get inelastic strain energy accumulated per cycle for postprocessing in ANSYS student edition’ is closed to new replies.
3587
1193
1086
1068
952
