How to get direct technical support on Ansys Access on Microsoft Azure
August 27, 2024 at 4:10 pm
Francis Poussin
Ansys EmployeeYou can ask your question directly in the forum for Ansys Access on Microsoft Azure If you need to report a technical issue directly to Ansys, you can use the standard technical Support process.
1) if you are managed by an Ansys Channel Partner
Please contact your partner via their usual Support process
2) if you are directly supported by Ansys, then Submit a Support Case via the Ansys Customer Support Space: https://customer.ansys.com/
- Summary: indicate “Ansys Access” + header of the issue
- Family: “Platform”
- Application: “ANSYS Cloud”
- Area:“N/A”
Viewing 0 reply threads
1495
1386
1209
