How to get data points at specific timestep in ANSYS Fluent?
    • ANSYSuser12
      Hi, I am working on another solidification model and I have made an XY plot for temperature along a line in the geometry and I have the simulation running up to 3 seconds. However, when I go to get the XY data points after the simulation, I am only able to obtain the data points for the last time step (at 3 seconds).
      I was wondering if there was an easy way of obtaining the specific data points for time steps in between (for example, if I wanted the time step at 0.5 seconds).
    • DrAmine
      If you want to the temperature along the line at different time steps you need to export the XY plot along that line at certain frequency and read the files back into Fluent as Data Sources or elsewhere.
    • ANSYSuser12
      Thank you for answering. Just wondering, how do you set up ANSYS so that it exports the xy plot at every 0.5 seconds?
    • DrAmine
      Using a journal file or TUI commands being executed every 0.5 seconds under "Calculation Activities".
  • The topic ‘How to get data points at specific timestep in ANSYS Fluent?’ is closed to new replies.
