August 9, 2020 at 4:38 am
RajasekarK123
SubscriberAugust 10, 2020 at 7:40 amDrAmine
Ansys EmployeeThis is not possible / or at least easy in Fluent as you might need annotation and the annotation capability is very limited. A lot of scheme will be required.nAugust 11, 2020 at 6:25 amKeyur Kanade
Ansys EmployeeAs Amine pointed out it is not easy in Fluent. nIf you need only representation for one time, you can plot contours without fill option. Then you can use annotation to write values in graphics window. nViewing 2 reply threads- The topic ‘How to get contour values inside the plot like in the given figure using fluent?’ is closed to new replies.
5649
1885
1404
1303
