April 24, 2018 at 12:34 pm
Seryoga
SubscriberHello everyone!
I have to set up a RGP-Table based simulation in CFX. The task is to simulate the cooling effect of throttled parahydrogen. Therefore I have to create a RGP-Table.
Is somebody aware of a tool which creates such a table using the REFPROP NIST Database?
Do I have to create a RGP-Table for liquid- and separately for the vapor-phase combining the two to a binary mixture or is Ansys able to separate the phases by just using only one RGP-Table?
Thank you for any advice or help!
Greetings
April 24, 2018 at 2:20 pm
raul.raghav
SubscriberDo you have access to RefProp? If you do, it's quite straightforward to create the RGP file. Attached is a zip file which has a program and a pdf explaining the procedure to create the RGP file from the NIST data.
You can either (i) create a separate RGP file for the liquid and gas phases and define the saturation properties; or (ii) create a single RGP file with all the properties along with the saturation properties, since a single RGP file can hold all these information.
April 26, 2018 at 1:00 pm
Seryoga
SubscriberHello Rahul!
First of all thanks a lot for your fast answer and the provided software!
I have tried to compile the RGP GEN from GitHub but encountered several issues. After compiling on Windows 10 64bit, I'm getting the Error "Out of memory" as soon as I start the RGP-table generation. No matter of the table size, RAM and adminrights. It also seems for me that there is a mistake in the code since the program is linked with (fortran-) datafiles that are no longer provided by the REFPROP 9.1 version. On Linux the compiled Generator refuses even to start.
If you have a working version I would be really thankful if you could provide me the compiled Generator. I also have access to RefProp.
I also tried the ZipFile, thanks! Everything works just fine except the organisation of the collums (picture).
Maybe someone has experienced something similar and has a easy solution for this type of bug.
But thanks a lot so far for everything!
Cheers!
April 26, 2018 at 1:07 pm
raul.raghav
SubscriberSeryoga, I personally have not used GitHub RGP GEN and it was suggested by a friend who used it in CFX 14.5.
But the zip file should work as it is the tool provided Ansys for generating RGP files. Could you share the RGP file that you generated? You might have to zip the RGP file and attach in your post.
April 26, 2018 at 3:01 pm
Seryoga
SubscriberSure!
I just reduced the size of the tables for a smaller file.
The other settings are untouched. Tested on Windows 7 and Windows 10. Unfortunately same bug.
Thanks for the support!
Greetings,
Sergjo
April 30, 2018 at 3:25 am
raul.raghav
SubscriberSeryoga, sorry for the late response. I checked your RGP file. I don’t think the organization of the columns would affect anything. I tried inputting the RGP file and i was able to create the homogeneous binary mixture of N2 and N2VAP. The only problem i had was with the saturation properties. Once i made a few changes to your RGP file according to the “Organization of an .rgp file” link I had posted earlier, it seemed to work for me. Did you figure out a way to solve your problem?
May 4, 2018 at 11:33 am
Seryoga
SubscriberHello Raul!
Thank you for your answer.
"sorry for the late response" - No worries!
"Once i made a few changes to your RGP file according to the “Organization of an .rgp file”" - You're right! I missed to add the line;
SAT_TABLE
10 4 9
Since the SAT_TABLE is the same as for the vapour phase, I don't have to copy it in the RGP file for the N2VAP right?
Furthermore I have a question belonging to the ANSYS RGP TOOL. Is it possible to generate the RGP files for other components than the ones which are listed in the dat.txt? I tried to change the fluids (names/formulas) in the collum but it didnt work for me...(using names of the components in the fluids folder).
To save time I'm currently working with an untested rgp-tool (beta version) which was made by the company I work for. The organisation and the values of the RGP file look very promising/right. As I'm not very experienced with ANSYS CFX Multiphase I started to simulate a simple heated pipe of water before starting to work on my actual and more complex thesis.
The target is also to achieve a phase change.
- I took the water.rgp file with waterLIQ/waterVAP values inside and created two seperate new materials:
waterLIQ with the thermodynamic state "liquid" using the water.rgp.
waterVAP with the thermodynamic state "gas" using the same water.rgp.
- Created a new material: Water combining the two materials waterLIQ and waterVAP into a homogenous binary mixture while still using the same water.rgp file for the Saturation Properties with the right Component Name for the SAT_TABLE.
Now after setting up the simulation, I'm facing a really annoying problem. Ansys refuses to start with the initial conditions I set up before. The initial static temperature on the Inlet of the heated pipe is set to 300K but however Ansys is starting at 398K. After ~200 iterations and a converging deviation the solver suddenly realizes the right initial temperature/pressure and also the right density. Around 50 iterations later the simulations starts to diverge and crashes.
Unfortunately I'm running out of ideas since I doulechecked everything. Have you ever experienced something similar?
Pipewalls are smooth. No Slip Wall. Inlet is subsonic. waterLIQ mass fraction is set 1.0 at the inlet.
Thanks for the help so far!
Sergjo
May 4, 2018 at 3:46 pm
raul.raghav
SubscriberTo create RGP files of other fluids, you can copy the contents of your fluid.fld to NITROGEN.fld (in the "fluids" folder) and edit the dat.txt file with the appropriate table size, Tmax, Tmin, Pmax and Pmin data. So the component names of your RGP files would still be N2 and N2VAP but it would hold information of your fluid fluidVAP
Your setup of Materials with RGP file in CFX-Pre sounds right to me.
Sometimes increasing the superheated range rectifies a lot of errors but I can't say for sure why or what the errors are in your case. If you could post a few images of the errors you're facing, I can get back to you with something.
May 7, 2018 at 4:36 pm
Seryoga
.Worked out fine for me! Big Thanks!!!
I'll try to make the setup of the simulation as transparent as possible for you;
- Heated Pipe 45x500 [mm] with monitoring points IN/PRE/MID/AFTER/OUT (as seen in the upper picure in yellow)
- Fluid:
- water.rgp as a homogenous binary mixture
- T: 274 [K] - 600 [K]
- P: 0.1 [bar] - 100[bar]
- Heat Transfer: Total Energy Incl. Viscous Work Term
- Turbulence: Shear Stress Transport
- Component Models: waterLIQ - Equilibrium Fraction /// waterVAP - Equilibrium Constraint
- Inlet:
- Subsonic
- Static Pressure 2 [bar]
- Flow Direction: Zero Gradient
- Turbulence: Medium (Intensity = 5%)
- Heat Transfer: Static Temperature 320 [K]
- Component Details: waterLIQ mass fraction 1.0
- Outlet:
- Subsonic
- Average Static Pressure Over Whole Outlet 1.8 [bar]
- Fluid Wall/Boundary:
- No Slip Wall
- Smooth Wall
- Heat Flux
- Mesh:
- Sweep Method
As described in the previous post, the solver is not starting with the given initial values (temperature & density). There are no errors in the first couple of iterations.
After a couple of iterations, the solver starts to converge and accepts the initial values. But as soon as this is happening the following warning occurs
A couple of iterations later I'm getting 'clipping-warnings' all over the values. Later as the solver is moving into the right direction of temperature and density values of the other monitoring points (as seen in the picture of the density graphs), the simulation diverges and crashes.
Double Precision is activated. Changing the time scale factor did not help. I'll also attach the water.rgp file at the end of this post (The table size is only 30x30 since I got the same deviation with bigger ones like 200x200).
Hope these Information are sufficient. If not, let me know!
Thanks a lot so far!
Sergjo
May 12, 2018 at 8:23 am
Moosarreza
SubscriberHi!
I'm absolutely thankful for the way you shared for rgp file generating;
but I have a question:
for generating data for another fluids what change should be done?
hope to hear soon;
Best regards. -
May 12, 2018 at 3:56 pm
raul.raghav
SubscriberSergjo, I don't think I'd be able to help you with the errors. But here are a few suggestions that I'd follow if I were you.
1. Perform an ideal gas simulation and get a converged solution. Now use this converged solution as the initial condition for your real gas simulation.
2. Try increasing the size of your table. Try with 300, 500 points etc. and see if things get any better or get solved.
May 12, 2018 at 4:00 pm
raul.raghav
SubscriberMoosarreza, I posted the following in an earlier comment. Hope this helps!
May 16, 2018 at 10:45 am
Moosarreza
SubscriberThanks alot;
best regards for you; -
June 7, 2018 at 12:11 pm
Seryoga
SubscriberHello Rahul,
Thank you for your advice. Unfortunately I'm still struggling with the simulation. I managed to start the Simulation with the initial conditions. But as soon as the Temperature/Pressure is reaching the boilingpoint of water I'm getting the following warning:
The Total Pressure becomes negative and causes other variables to clip. As a result the simulation is not converging.
I think I will open a new thread since this topic is very underexplained in the ansys documentary and has nothing to do with the creation of an RGP file anymore.
I also tested the RGP file with a single Phase simulation. Everything went very well and converged.
Best regards,
Sergjo
July 18, 2018 at 11:32 pm
gonzix94
SubscriberHi,
I am currently performing the design of a centrifugal compressor working with supercritical CO2 and I wanted to know if the NISTtoRGP application it was posted before can be used for generating the properties table in that state.
I have tried to get values from 1 MPa to 30 MPa (Pcrit=7.37MPa), but it is a bit strange because while creating the tables this message appears:
TPRHO failed so extrapolating 2D data.
P/Pc=(increasing factor until reaching the critical pressure)
I have seen that this does not happen if I just go beyond the critical point.
Can anybody help with this? How can I create a look-up table that include two-phase and supercritical states?
In addition, when I run a simulation with the rgp file I am attaching and my simulation quickly "converges" after like 4 iterations after clipping a lot of variables and putting a lot of walls in the outflow region to avoid reverse flow!!! A total non-sense... Any guesses what is going on?
My inlet conditions are the following ones, just in case it helps:
P=7.69 MPa
T=305K
m=3.06 kg/s
V=25.67 m/s
N=75000 rpm
Thanks!!
August 27, 2018 at 9:23 pm
abbas
SubscriberHello everybody,
I am trying to create two different RGP tables in CFX, which one of them is fluid and another one is vapor. Should I define two different saturate line too for both phases? I simulate a co2 two phases flow and I need both phases. Does anyone have this experience or similar?
Thanks
Abbas
August 28, 2018 at 7:33 am
DrAmine
Ansys EmployeeHi,
You will need both materials as you need to account for phase changes or at least the flow of this two aggregate states in one simulation. Actually there is a more elegant way to get the RGP tables out of the shipped NIST property files which come with the Fluent. This way involves the usage of AIM im batch.
September 6, 2018 at 1:55 am
Stoki
SubscriberHi,abenhadj,
I'm very interested in the "more elegant way" to get RGP file by AIM. Would it be possible to give more details or some examples?
Thanks.
Stoki
September 6, 2018 at 5:52 am
DrAmine
Ansys EmployeePlease contact your ASC at your university who might check there with local support. The approach is via the AFD solver (AIM) where the NIST materials are translated to RGP files.
September 27, 2018 at 1:09 pm
abbas
SubscriberThanks, dear abenhadj.
So, based on your suggestion, I don't need to generate the RGP table for CFX and I can use AFD solver. My question is: my work is in two phases of CO2 simulation. So, according to AFD solver, both phases will be generated? Could you give me some references about how I can use AFD solver and etc.?
Best regards
September 27, 2018 at 2:32 pm
abbas
SubscriberI have generated the RGP table for both liquid and vapor CO2. I should define both liquid and vapor saturation line because I have two phases but when I use the Homogenous Binary Mixture to introduce both materials, I am facing with saturation properties. Does anyone have the experience of generating RGP table for liquid and vapor phases?
Best regards
October 18, 2018 at 8:31 pm
abbas
Subscriber -
October 23, 2018 at 7:42 pm
Seryoga
SubscriberHey Abbas,
you can choose either the vapour or the liquid phase of your table since the saturation properties have to be the same for both of the phases (Official Ansys Support confirmed this Setup). So use: table--> either co2liq or co2vap. Please be aware that the name of the fluidphase in your rgp-file has to be max. 8 characters long!
I spent a lot of time at this topic...so after all I want you to know a few things:
The generation of the tables is really a thing for itself. ANSYS, Inc. has an unreleased table-creation-tool (Based on Ansys 18.2) which is the best so far to use. It uses an algorithm which allows it automatically to refine the steps near the boundaries or areas where the variables change rapidly. Basically the programm decides for it self how big the stepsize in the given Temperature/Pressure-Intervall has to be. This type of algorithm helps to establish a stable and more accurate simulation.
Since the tool is not released yet, there is no chance to get it. I just had the luck to test it for a period at my company.
The other thing is, and I think it's the most important one to learn from this topic:
It's NOT possible to achieve a phasechange/boiling of a fluid based on heatflux in CFX (with RGP-tables).
There's simly no function built into the solver which allows it to calculate the growth of the bubbles and the flow separation of the heated fluid (Since this is a really big topic for itself) from the heated wall. (Official ANSYS support confirmed this problem) Therefore the simulation crashed every time.
Best regards,
Seryoga
October 24, 2018 at 9:34 pm
abbas
SubscriberHi Seryoga,
Thanks for your advice. So, according to you, It's not possible to simulate the phase change in CFX? I am working on a pipe that at the inlet, I have just vapor phase but at the outlet, I have both liquid and vapor phase. Therefore, I can't simulate it on CFX?
Best regards
Abbas
October 25, 2018 at 5:34 am
DrAmine
Ansys EmployeeI used RGP tables for the validation of a sub-cooled boiling case with real NOVEC-649.
October 25, 2018 at 12:24 pm
Seryoga
SubscriberDear abenhadj,
maybe you can tell us more about your simulation?
Ansys's Support-Team confirmed me, that a steady-state simulation of boiling water/phasechange based on heatflux in a horizontal pipe is not possible.
So please tell us more about your certain case and how you established a working setup.
Thanks!
Best regards,
Seryoga
October 25, 2018 at 12:48 pm
Seryoga
Hi Seryoga,
Best regards
Abbas
I am also working on an expansion of a liquid phase into a vacuum. The phasechange works fine as a result of the pressure drop. Please note, that the walls of the pipe are adiabatic in this case. The previous post I was talking about the problem with a heatflux...so depending on your case it might work.
Maybe I'll have the possibility to use the tool again...so I'll be able to create the proper RGP tables for you if you want. Just give me your pressure and temperature intervalls.
Best regards,
Seryoga
October 25, 2018 at 1:22 pm
DrAmine
Ansys EmployeeThe wall heat partitioning strategy underlying in the RPI Wall Boiling Model should work in vertical and horizontal simulations. However if you have horizontal heated walls, is more likely that you have pool boiling than forced convection boiling. The correlations for the submodels of the RPI model were derived for forced convection cases.
October 25, 2018 at 3:56 pm
abbas
SubscriberHi Amine
When you generate two different RGP and after that two different material, for example, liquid and vapor. You just added them into your default domain? Or you create a homogeneous binary mixture and added three fluid into the domain?
Thanks
October 25, 2018 at 5:59 pm
DrAmine
Ansys EmployeeDepending on the on the modeling approach you want to deploy it might differ. For example for using the equilibrium phase change just use the binary mixture as your working fluid and define the vapor component as equilibrium fraction.
I highly recommend that you go through the tutorial axial turbine stage where IAPWS EOS has been used
October 25, 2018 at 8:11 pm
abbas
SubscriberThanks for your advice. Actually, I have simulated my project in a single phase and it worked. I am simulating vortex tube which at the inlet I have a vapor phase but at the outlet, I have both phases ( liquid and vapor). So, in this case, should I use a binary mixture or I should add both materials in my default domain and in this case, should I consider the liquid phase as a droplet or a dispersed?
Best regards
Abbas
October 26, 2018 at 6:12 am
DrAmine
Ansys EmployeeThe binary mixture is also require to get the saturation properties and to link it to the phase change even if you decide to use an inhomogeneous approach or droplet phase change model. Please carry out the tutorial I mentioned to get started and to understand some modelling aspects in CFX Multiphase.
October 26, 2018 at 9:41 pm
abbas
SubscriberThanks for your advice. I couldn't find the tutorial axial turbine. Could you possibly send the link of the tutorial?
Best regards,
Abbas
March 11, 2019 at 6:38 am
omidne
SubscriberHi abbas
May I ask you how you generate the RGP for CFX?
Sincerely yours
Omid
March 11, 2019 at 7:11 am
DrAmine
Ansys EmployeeHi Omdine, Please contact your ASC at your university who might check there with local support. The approach is via the AFD solver (AIM) where the NIST materials are translated to RGP files.
I hope Abbas can contact you directly and provide you with the way to do that.
June 7, 2019 at 1:59 am
casale
SubscriberHi!
Does this exe generate metastable property and spinodal curve ?
I need to calculate non equilibrium condensation.
Thanks
December 3, 2019 at 1:37 pm
conni
SubscriberHi,
I want to use the file provided by raul.raghav for the creation of a RGP-Table. I noticed that the dat-File takes Inputs for temperature and pressure range in deg Rankine and psia Units. Will the RGP file created in this way work with CFX running in SI-Units?
Thanks in Advance and Kind regards,
conni
- The topic ‘How to generate and setup RGP-Tables for CFX multiphase flow simulations’ is closed to new replies.
