August 23, 2021 at 5:30 am
Ulfah
SubscriberWhen I tried to interpret the following code, i got a message error 'line 6: parse error.'
#include "udf.h" #define Cd 0.2 /* usually between 0.1 - 0.3 ; lambda = Cd * LAD */ #define LAD 2.0 real A1t = 1.0; /* Betap */ real A2t = 5.1; /* Betad */ real A3t = 0.9; /* closure constant cepsilon4 */ real A4t = 0.9; /* closure constant cepsilon5 */ DEFINE_SOURCE(xmom_source,c,t,dS,eqn) { real x[ND_ND]; real source; real U = C_U(c,t); real V = C_V(c,t); real W = C_W(c,t); real VEL = sqrt(C_U(c,t)*C_U(c,t)+C_V(c,t)*C_V(c,t)+C_W(c,t)*C_W(c,t)); real k = C_K(c,t); real e = C_D(c,t); real rho = C_R(c,t); C_CENTROID(x,c,t); source = -Cd*LAD*rho*VEL*U; dS[eqn] = -Cd*LAD*rho*(U*U/VEL + VEL); return sourAugust 23, 2021 at 8:27 amaitor.amatriain
SubscriberAt a glance, you have not closed the square bracket
August 23, 2021 at 9:43 amRob
Forum ModeratorThere's also a ? symbol in line 1: check for white space characters too.
August 23, 2021 at 10:03 amaitor.amatriain
SubscriberAnd "sour" should be "source" in the last line
August 24, 2021 at 12:15 amUlfah
SubscriberSorry this is the real code
#include "udf.h"┬Ø
#define LAD 2.0
real x[ND_ND];
real source;
real U = C_U(c,t);
real V = C_V(c,t);
real W = C_W(c,t);
real k = C_K(c,t);
real e = C_D(c,t);
C_CENTROID(x,c,t);
return source;
August 24, 2021 at 9:54 amRob
Forum ModeratorAssuming the white space character isn't present, check if Cd is used elsewhere in the code: avoid 1-2 letter variables as we may use them elsewhere. A parse error warning is typically triggered on the line after the mistake, or rather the next line with text as the code found a fault but didn't know it was a fault until the next bit of code comes along.
August 24, 2021 at 10:38 amUlfah
SubscriberThank you for your help. I rewrote the code and I believe there was a white space character. I tried to interpret the new code and there seems to be no error occurred. However, I am confused with the message on the console which can be seen in the picture I attached below. What does this message indicate?
August 24, 2021 at 3:27 pmRob
Forum ModeratorIt's the result of the interpreter running through all of your commands. If it doesn't give an error or lots of warnings you can generally ignore it: it may mean something but no one I know has ever bothered trying to figure it out.
Viewing 7 reply threads- The topic ‘How to fix parse error in the following UDF code for my Fluent simulation’ is closed to new replies.
5799
