January 22, 2021 at 6:45 pm
vibrachid
SubscribernMy question is how we calculate Strain modes shapes. similar to the displacement mode shape, the strain mode shape was defined as the surface strain response of the structure when it vibrated at a certain resonant frequency. a built-in beam measuring 1006x46x5 mm3. E = 220 Gpa, ? = 0.3, density = 7896 kg m3. a unit force applied to one of the vertices of the free end. I carried out the modal analysis after I carried out the harmonic analysis (from the solution tab). I found the frequency response function of displacement, acceleration and strain . after to find the strain mode shape, I calculate the normal elastic strains corresponding to the resonance frequencies and I'm not sure that's the right answer. during the calculation of normal elastic deformation we must choose the frequencies and the phase angle (Sweeping phase ?) then my question, which sweeping phase I should take and is it the right procedure to have the strain mode shape . Thanks in advance.n -
January 29, 2021 at 12:08 pm
Ashish Khemka
Forum ModeratornnThis is a duplicate post (/forum/discussion/23773/how-to-find-strain-modes-shapes#latest). I will mark this post resolved.nnRegards,nAshish Khemkan -
January 29, 2021 at 5:07 pm
1shan
Ansys EmployeenA modal analysis/ free vibration analysis would give you the scaled mode shape. The corresponding scaled normal strain and normal stress are called a the strain & stress modes. You don't need to run a harmonic analysis for finding strain mode shapes. n -
February 3, 2021 at 10:16 pm
- The topic ‘how to find strain mode shape using ansys workbench ?’ is closed to new replies.
