March 25, 2020 at 4:46 pm
user deleted
SubscriberHello Everyone.Â
I'm new with Ansys. Could someone advise me how to find out where exactly mesh problem is?
There is a failed mash on some part of my 3D model. I've decreased a mesh body size for that part. But it hasn't helped.Â
I don't know what else to do.
My Parasolid file is here:Â https://drive.google.com/open?id=1VAoEwSCj5UjdHlVwte69-ddnSL18y78V
I would really appreciate any help.
March 25, 2020 at 5:18 pm
peteroznewman
SubscriberGordi, two weeks ago, you learned the value of midsuface models. Did you forget that lesson?
March 26, 2020 at 3:50 am
user deleted
SubscriberYes, i know. But it is inconvenient with large model to use the midsurface especialy if you don't know which surface needs to be repair.
March 26, 2020 at 4:38 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.Â
suppress everything except the body which is failing in meshing.Â
right click on error and click show problematic geometry. observe geometry carefully at the location. you may need to change geometry or meshing controls at that location.Â
from initial image, it looks like you have very coarse mesh on the faces. you may need to use face meshing.Â
please search through community and you will find many solution on meshing.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘How to find out mesh problem?’ is closed to new replies.
4673
1565
1386
1236
