TAGGED: creep, creep-analysis, creep-constants, deflection
April 5, 2023 at 2:37 pm
Joshua Davies
SubscriberHello All,Â
I am trying to mimic my experimental results with a model in ANSYS, and incorporate creep.Â
The experiment is simply measuring deflection of this old timber over the course of a few weeks in order to try to find a few material properties.Â
However, how do I find the constants purely from the data below?
Any help would be massively appreciated.Â
Thank you in Advance!
April 10, 2023 at 2:23 pm
John Doyle
Ansys EmployeeI assume by "Norton-Bailey"Â you mean an expression of the following form:Â Â
In Ansys, you can curve fit the Time Hardening Creep expression, with C4 set to zero.Â
You would have to convert your displacment values to an equivalent strain (=delta_L/L).
Please refer to Chapters 4 and 6 of the MAPDL Material Reference Manual or more details.
July 31, 2023 at 10:05 am
Chandra Sekhar Narra
Subscriber -
July 31, 2023 at 10:08 am
SubscriberDear Joshua Davies,
I saw your post about the calculating the creep constants from the experimental data. Have you found the solution for this? while now I too have the same problem, I could not find the right solution.
Could you please help me with that?
Iam looking forward for your response.
Kind regards
Chandra
- The topic ‘How to find Norton-Bailey Creep Constants?’ is closed to new replies.
5274
1885
1403
1262
