TAGGED: apdl-commands, mechanical-apdl, write-node-file
May 26, 2021 at 7:57 pm
OnurOnder
SubscriberHave a nice day. I am trying to prepare a code on Ansys Commands (APDL). Thanks to this code, I am trying to pass the node numbers on the whole body to an array (actually I want to see these values on a txt). I found some codes on the internet. Based on these, I tried to create my own code. However, the code I wrote is not working properly. Can you help with this?
June 1, 2021 at 3:36 pmGovindan Nagappan
Ansys EmployeeCan you copy paste the code you have now?
Can you attach an image that shows s sample output you need?
Viewing 1 reply thread- The topic ‘How to find node numbers in ansys apdl’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1221
1118
1015
