February 5, 2021 at 4:04 pm
mese
SubscriberWe have a 3D fluid model consisting of the space between two concentric cylinders for which I do not know how to create the fluid volume.Â
February 8, 2021 at 6:19 amKeyur Kanade
Ansys EmployeeUse inner cylinder faces. nThen create faces for outer cylinder. Now create the top and bottom annular surfaces. nSo basically create all required surfaces separately. nThen use Stitch option to stitch them together to create solid body of space between cylinders. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynFebruary 11, 2021 at 10:40 pmmese
SubscriberUse inner cylinder faces. Then create faces for outer cylinder. Now create the top and bottom annular surfaces. So basically create all required surfaces separately. Then use Stitch option to stitch them together to create solid body of space between cylinders. Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Community/forum/discussion/comment/105878#Comment_105878
Thank you, that's it. nWell, I did not expect that I would need to use something in the Repair menu, and the usual options such as Pull, Fill and Extract Volume do not work here ?. The act of filling the space between two surfaces is typical in fluid models nViewing 2 reply threads- The topic ‘How to fill space between faces in SpaceClaim?’ is closed to new replies.
4939
1639
1386
1242
