3D Design
3D Design
how to fill solid between two surfaces?
    • deepmech.maurya
      hello sir,
                       i have to fill solid between two surfaces but surfaces are offset.
      attached video will clear my question easily.
      https://youtu.be/UmF24aqvCPE
      image is also here s1 and s2 are two surfaces
      thanks
      You can use Replace Face.  Attached file is from Release 18.2
      https://youtu.be/sR3_7CsoZEQ
  • The topic ‘how to fill solid between two surfaces?’ is closed to new replies.
