October 31, 2021 at 1:35 am
mwhitby
SubscriberI did FDE analysis for my simulation. Then I calculated the modes and got a data table inside the Eigensolver Analysis Tab called Mode List. From this data I would like to extract the loss and the TE polarization fraction. Ideally I would like to be able to extract these values and assign them to variable names, however it would also work if I can export the full data table to a .csv file. Is there any way to do this?
October 31, 2021 at 1:37 ammwhitby
SubscriberI need to do this in script.
November 1, 2021 at 6:34 pmGuilin Sun
Ansys EmployeeMay I know why did you write repeatedly ?
you can first check what quantities can be output:
?getdata("mode1");
?getresult("mode1");
then you can script to get them:
eg
E=getresult("mode1","E");
loss=getresult("mode1","loss");
please try.
November 1, 2021 at 11:33 pmmwhitby
SubscriberMy apologies for the repeated comments. I only meant to add it once but there must've been some sort of system error.
Thank you for your help! I am having some slight issues while trying this.
Firstly, the loss = getresult("mode1","loss); code outputs loss = 509627 whereas in the table for mode 1 loss is listed as 5096.3. Is this a scale problem? Is there a way to fix this?
Secondly, the E = getresult("mode1","E"); code doesn't give me the TE polarization fraction. It says that E = E vs x, y ,z ,lambda/f. How can I get this to give the TE polarization fraction?
November 1, 2021 at 11:38 pmmwhitby
SubscriberTo try to fix the code for TE polarization fraction I used TE_polarization_fraction = getresult("mode1","TE polarization fraction"); . This gave me 0.10235 whereas in the table it was listed as 10. Again the scale seems to be off. Is there a way to fix this? Thank you!
November 2, 2021 at 12:09 amGuilin Sun
Ansys EmployeeThey are the same Thing: On the list it is the percentage whereas in the script it is actual value: 0.10235 is 10 percent .
For the loss, the list shows dB/cm, whereas in script it is dB/m.
Please note that the script unit is mks system.
https://en.wikipedia.org/wiki/MKS_system_of_units
November 2, 2021 at 12:21 ammwhitby
SubscriberThank you very much for all of your help! I greatly appreciate it.
Viewing 10 reply threads- The topic ‘How to extract values from Mode List data in Eigensolver Analysis’ is closed to new replies.
5864
