August 3, 2020 at 3:08 am
Karthik Remella
AdministratorHow to export volume mesh and preview surface mesh from Ansys Meshing in .msh format ? -
August 3, 2020 at 4:15 am
prajput
It can be useful to export Hexa volume mesh connected to triangular surface mesh from ANSYS Meshing to generate the volume mesh in Fluent Meshing. This is not the default behavior, user must set the option "Export Preview Surface Mesh" to Yes in the Details of Mesh under Defaults.
August 3, 2020 at 7:30 am
Karthik Remella
AdministratorIn Fluent we can directly write compressed file as *.cas.gz. Can we write *.msh.gz file while exporting mesh from workbench meshing? -
August 3, 2020 at 10:20 am
prajput
No, you can only export it as *msh file. Later you can read it in Fluent Meshing and write *.msh.gz file.Â
August 3, 2020 at 10:27 am
Karthik Remella
AdministratorCan I export geometry format from meshing? -
August 3, 2020 at 10:43 am
Keyur Kanade
Ansys EmployeeYou can export only *.pmdb format from meshing. If you want to export other formats then you will have to have geometry in SpaceClaim or Design Modeler.Â
Viewing 5 reply threads
- The topic ‘How to export volume mesh and preview surface mesh from Ansys Meshing in .msh format ?’ is closed to new replies.
Ansys Innovation Space
1313
1142
1068
1008
