April 4, 2024 at 1:35 am
Bob
SubscriberI am conducting an experiment where two objects collide using explicit dynamics.I want to extract the results at the point when maximum stress occurs.However, when you export Equivalent Stress, only the results from the last time are extracted.ÂHow can I get the results at the point when maximum stress occurs?Or Can't we export the values from all steps, not just the values from the last step? (as follows) -
April 4, 2024 at 7:35 am
Akshay Maniyar
Ansys EmployeeHi Bob,
You can export results for a particular time with the same option 'Export < Export text file', but before that, you have to evaluate the result for the time for which you want to export the results. First, right-click on the graph with the maximum value and evaluate the result for that time and then export the text file.
Thanks,
Akshay Maniyar
- The topic ‘How to export the results when maximum stress occurs’ is closed to new replies.
