How to export the node coordinates for a Fluent mesh?
    • ansysuser
      I need to extract the node coordinates for all nodes on a 2D Named Selection edge.  How can I accomplish this.  I am using Workbench with a Fluent Module.
      Thanks
    • Amine Ben Hadj Ali
      You can do that by exporting coordinates of the boundaries into ASCII format in Fluent or any other format.
    • ansysuser
      Thank you, but how to do this?  If I right click on a boundary that is a named selection, for instance, there is no export option.  So what are the steps to do it?
    • Karthik Remella
      Administrator
      Load the mesh in FLuent. Go to File -> Export -> Solution Data and use the following settings as shown in the dialog box.
      Best Regards,
      Karthik
    • MuhammadAhsanZeeshan
      Hello Everyone,
      I made surface along my local coordinate at my 3d model in ANSYS workbench 2022 R1. I want to export normal stress data in my local coordinate. when i export normal stress data, it will obtain along global coordinate. But I want normal stress exported data in local x, y and z coordinates not along global coordinate.
      Which solver are you using?
Viewing 5 reply threads
  • The topic ‘How to export the node coordinates for a Fluent mesh?’ is closed to new replies.
