TAGGED: ansys-fluent, ansys-student, cfd-post, fluent, fluid
July 21, 2021 at 9:56 am
PHAMHUUHOANG
SubscriberHi everyone.
Im doing my research about simulate ice on airfoil using FENSAP - ICE
After simulated, i want to export the lift coefficient and drag coefficient of the airfoil.
For example, in these picture, i tried to export the lift coefficient and drag coefficient of the NACA0012 airfoil.
I read that in FENSAP solver of the FENSAP - ICE, it can solve the lift coefficient and drag coefficient of the airfoil, so i used the FENSAP solver.
As you can see in the picture, i set up the CFL number at 50 and Maximum number of time steps at 10
July 25, 2021 at 7:22 pmShoaib Shah
Ansys EmployeeHi Pham
Good news is that the steps you are showing are correctly done. Just like the other residuals you need the lift and drag coefficients to converge. The 1st value would be entirely wrong.
The solution has to be sufficiently (fully) converged (i.e. NS, Energy, Average residuals etc.), usually after 300-1500 iterations (depending on the case). In fact, the aerodynamic coefficients e.g. lift and drag are an additional monitor to check for convergence. In the latter cases, you would normally see the lift and drag values remain unchanged (or the delta between the final 2 iterations is really low ~0.1%).
So in a typical simple airfoil case, lets assume, the solution converges after 300 iterations. You should export the CSV, and check the last few 10-50 iterations and see the change in values in lift and drag. If they are <0.1% , a). it confirms the solution has converged or is close to convergence. and b). You could decide to either take the last value as the final lift/drag value or average out the last few iterations where there is little or no change in the lift or drag.
July 27, 2021 at 12:35 pmPHAMHUUHOANG
SubscriberHi sshah !
Thank you so much !
This helps me a lot.
PHAM HUU HOANG
Viewing 2 reply threads- The topic ‘HOW TO EXPORT LIFT COEFFICIENT AND DRAG COEFFICIENT IN FENSAP – ICE’ is closed to new replies.
5884
1306
