February 17, 2021 at 4:06 am
feroz.mulani85
SubscriberI want to export solution data from solver to excel file, e.g the values of Nusselt number at different locations, as shown in the image attached. I want to export those values of Nusselt number according to distance, to an excel sheet.
February 17, 2021 at 4:39 amYasserSelima
SubscriberIn the same panel you selected xy plot, check the box write to file.nThis will give you file.out ... open it with excel, it will opennFebruary 17, 2021 at 5:24 amferoz.mulani85
SubscriberThank you very much Mr. Yasser, i tried the way you have written, i created a file by write option but the file is not opening in excel.nFebruary 17, 2021 at 5:25 amferoz.mulani85
SubscriberIn the same panel you selected xy plot, check the box write to file.This will give you file.out ... open it with excel, it will open/forum/discussion/comment/107028#Comment_107028
Thank you very much Mr. Yasser, i tried the way you have written, i created a file by 'write' option but the file is not opening in excel.nFebruary 17, 2021 at 11:22 amRob
Forum ModeratorFluent writes a text file, in Excel you need to open/import delimited text. nFebruary 17, 2021 at 12:56 pmYasserSelima
SubscribernWatch thisnhttps://www.youtube.com/watch?v=vOZ80EMEwEk&ab_channel=CodiblenFebruary 20, 2021 at 3:09 amferoz.mulani85
SubscriberThank you very much Mr. Yasser & Mr. Rob. Your answers were really helpful.nViewing 6 reply threads- The topic ‘How to export data from ansys fluent to excel sheet ?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3882
1414
1241
1118
1015
