3D Design
3D Design
How to export a solid as .stl file with named selections?
    • mkhademi
      Hi everyone,
      I have created a solid in Spaceclaim, and now I want to save it as a .stl file. I have named selections on my geometry such as inlet, outslet, surface... but when I save it as .stl file, a whole geometry is the output but I need to have those boundaries as seperate stl files. How can I do this?
      Thank you,
      Mahdi.
    • Charudatta Bandgar
      Hello Mahdi,
      I am not sure if that will be possible, since the faces will be split into multiple facets it will not retain the named selection information.
      Regards
  • The topic ‘How to export a solid as .stl file with named selections?’ is closed to new replies.
