July 31, 2024 at 12:00 am
zzhang868
SubscriberHello, I am wondering how I can export temperature from all meshed points instead of just surface. I added "temperature", "locx", "locy" and "locz" under solution of "transient thermal analysis" and export them as txt files. Based on the coordinates from "locx", "locy" and "locz", I align "temperature" towards each node. In all txt files, node number does not start from 1. Besides, the visualization result from the alignment is wierd.
August 1, 2024 at 1:09 pm
August 1, 2024 at 1:11 pm
zzhang868
SubscriberThe node sequence is not very important. I add LOCX, LOCY, LOCZ, and temperature under solution of transient thermal analysis. Then, I align the temprature value with corresponding its location (locx, locy, locz) and visualize it using python. However, it does not match what I see in the ANSYS. It should be a cuboid.
August 1, 2024 at 1:15 pm
zzhang868
SubscriberI see. I am wondering what is the difference between my approach and the approach you showed above? I am thinking that "LOCX", "LOCY", "LOCZ" also record the location. Thanks!
- The topic ‘How to export 3D visualization instead of ANSYS .avz?’ is closed to new replies.
5809
