August 23, 2024 at 2:58 pm
Mehdi Baghaee
SubscriberI am doing transient analysis. I want to exert time varying forces on each nodes of a surface in global Z direction (not nodal direction) during simulation.Â
My forces are calulated and nested on a vector (array) which the location of the values in the array relates to the node numbers.Â
I want to know how is it possible through ANSYS apdl commands without using a do loop? (simply by F command)
August 24, 2024 at 8:35 am
Yolanda GStewart
SubscriberHello! I am also in the process of analyzing to apply force to a group of nodes in a global direction when analyzing instantly? This process is quite complicated so you need to learn and develop more to handle situations in time. Although I am analyzing, I still have to learn a long time to be able to analyze most accurately. You should check out geometry dash subzero to gain more knowledge and skills for yourself.
August 25, 2024 at 11:49 pm
Mehdi Baghaee
SubscriberAny Comment?
5849
