February 25, 2021 at 4:19 pm
Conss
SubscriberHello,
I did a 3 point bending test simulation on a composite sample by using ACP, mechanical model for the support and the load applicator and static structure for the simulation. I would like to evaluate the strength in Newton but i only found strain and stress in mm/mm or MPa.
Here is a picture of the simulation
February 25, 2021 at 5:07 pmramgopisetti
SubscriberOk so in what context, do you mean strength, can you elobrate?.ewton is unit of Force and in what way u want to infer the Strength in your model, can you elobrate?nFebruary 26, 2021 at 12:57 pmConss
SubscriberHi, I need to do a graph of force versus displacement using the results of my 3 point bending simulation. So I would like to recover the force which is applied to the center of my sample during the simulation and therefore to be able to do my graph because I have already been able to recover the displacement as a function of time.n
n
March 1, 2021 at 12:30 pmConss
SubscriberMarch 2, 2021 at 7:16 amramgopisetti
Subscriberdid you tried using force prob and choose displacement as the boundry condition, can you able to post what you getnCheers, nRamnMarch 3, 2021 at 9:32 amMarch 3, 2021 at 3:26 pmramgopisetti
SubscriberHappy that your have got the result, can you accept the answer.nCheersnRamnViewing 6 reply threads- The topic ‘how to evaluate the strength (in N) at the end of the simulation in static structure?’ is closed to new replies.
4904
1598
1386
1242
