TAGGED: ansys, ansys-mechanical, ansys-student, ansys-workbench, apdl
April 19, 2022 at 3:50 pm
Chika400
SubscriberHello,
How can I evaluate the accumulated equivalent creep strain in ANSYS Workbench Static-Structural?
Are there APDL commands for this?
April 20, 2022 at 11:50 amChika400
SubscriberHi,
Please, can someone post the result to this because I need it urgently for my work?
April 20, 2022 at 1:13 pmErKo
Ansys EmployeeAs far as I am aware, there is no option as far as I can see to plot or obtain accumulated creep strain, only plastic strain.
All the best
Erik
April 20, 2022 at 1:16 pmChika400
SubscriberHello Erik Thank you for your response.
A paper I consulted stated that I can get the accumulated strain using the SEND CREEP APDL command NLCREQ in Ansys.
Please, is there a way I can get this script?
April 20, 2022 at 1:32 pmErKo
Ansys EmployeeHi
Yes, I just saw that also in the help manual (say for the solid186 or 187 you are using).
Yes you should be able to get that perhaps with APDL commands see-
the ESOL and ETABLE commands.
All the best
Erik
April 20, 2022 at 1:41 pmChika400
SubscriberHello Erik Thank you for your this information.
I have checked the ESOL- General Item and Component Labels in Table 124 and I see that the NL:CREQ and SEND:CREEP items and components are what I need.
However, I am using Workbench and I am very new to APDL scripting. Please, Could you direct me on how to get the script so I can use it in Workbench?
Thanks Erik,
Chika
April 20, 2022 at 1:54 pmErKo
Ansys EmployeeHi
If you search the forum and the internet the will be examples on that.
e.g. For workbench see also the tech demo example 35 where they plot the accumulated strain I believe.
thank you
Erik
April 20, 2022 at 2:12 pmApril 20, 2022 at 8:32 pmChika400
SubscriberHello jjdoyle Thank you very much for your answer. The problem has been solved!
Viewing 8 reply threads- The topic ‘How to evaluate accumulated equivalent creep strain in ANSYS Workbench’ is closed to new replies.
5734
