LS Dyna
LS Dyna
How to enter LS-DYNA MAT_WOOD engineering data
    • yuu0910
      I would like to use MAT_WOOD in LS-DYNA.
      However, I cannot find MAT_WOOD in the engineering database.
      Could you please tell me where the MAT_WOOD item is?
    • armin.abedini
      For material models that are not yet available within the Engineering Data application, you can add them in the Workbench as keyword snippets.
      Right click on the geometry and then insert Commands (see screenshot below). Please note that the format of the *MAT card should follow the format provided in the LS-DYNA keyword manual: https://www.dynasupport.com/manuals/ls-dyna-manuals/ls-dyna_manual_volume_ii_r13.pdf
    • yuu0910
      Thank you for teaching me.
