December 10, 2021 at 10:12 am
Muzzammil
SubscriberI am using ansys 19.2, I need to write an expression for a heat source in my simulation. I see that there are only 2 options available these are constant and New input parameter.
So i would like to know how to enable it, as in default setting it doesn't show up.
December 10, 2021 at 2:14 pmRK
Ansys EmployeeHello,
You can go to named expressions , create an expression for heat source.
December 10, 2021 at 2:33 pmMuzzammil
SubscriberNamed expression is not available here by default
October 4, 2023 at 11:54 amMasoom Zahid
SubscriberViewing 3 reply threads- The topic ‘How to enable the “Named expressions” option in fluent 19.2’ is closed to new replies.
5984
1307
