February 12, 2024 at 6:42 pm
February 13, 2024 at 7:20 am
Atharv Joshi
Forum ModeratorHi Felipe,Â
Let me check this and get back to you.Â
Thanks and Regards
Atharv -
February 13, 2024 at 3:25 pm
felipefreiredecarvalho
SubscriberHi Atharv,
it's ok, thanks for support
February 13, 2024 at 3:28 pm
Atharv Joshi
Which version are you using in the screenshot, did you see this option in any of the videos?
Unfortunately, I don’t see any such options in the latest versions of the software.Â
Thanks and Regards
Atharv -
February 13, 2024 at 5:41 pm
SubscriberStudent Version 2023 R2
March 10, 2024 at 9:51 am
debabratadassbp767
SubscriberHi Felipe
Have you fixed the problem of finding that constraint? -
March 18, 2024 at 9:47 am
Atharv Joshi
Click F1 and activate the overlay for guiance on the tool.
What exact constraints are you trying to set?Â
Thanks and Regards
Atharv -
March 19, 2024 at 2:26 am
SubscriberÂ
Hi Debabrata Das, I didn't try yet, but I downloaded the latest version and probably on next weekend I’II install it.
Thanks for support.
March 19, 2024 at 2:33 am
SubscriberHi Atharv Joshi, Oh nice, I'II install the latest version, but before I'll try this method.
Thanks for support.
Regards.
March 25, 2024 at 1:05 am
SubscriberHi Atharv Joshi, how are you?
    Sorry, I didn't observe your question, I'm trying to apply a restriction in a Robotic Arm this class (https://www.youtube.com/watch?v=08of8OxR2BE&t=2s) on minute 04:00 of video, the instructor created a tangent restriction on circle, but I could not because that problem.
Regards.
March 26, 2024 at 9:55 am
Atharv Joshi
Thanks for sharing the video. I will check this and let you know.Â
Regards
Atharv -
March 28, 2024 at 1:12 pm
Atharv Joshi
In this video the instructor is using the Change Angle feature with the reference construction line.
You can perform the same operations using Dimension Tool from Design Tab while sketching.First add the diameter for circle as shown.Â
Select the tangnet and construction line to add the angular dimension as per drawing.Â
Later on you can use "Create Corner" to extend the tangnet line to the edge.ÂThanks and Regards
Atharv
- The topic ‘How to enable the constraints of tangent line tool?’ is closed to new replies.
5674
1890
1419
1304
