3D Design
3D Design
How to draw D,DD and DDQ coil for wireless charging in maxwell 3D as attaced pic?
    • Hussein369
    • 1shan
      You could create a set of points and joint them with connecting lines to represent the centerline of your coil. Next draw a circular cross section at the starting point and use the pull command along with the sweep option to create the solid coil.
      Regards Ishan.
    • xduan916
      how to simulate dd coils using coil sheet, as the yellow coils are in series, so, how can we simulate it as series connection? 2、how to excite current for the coils, excite one coil or both two?
    • ErKo
      Hi
      Post this in the electronics forum (this is for 3D design, say SC or DM CAD modelers).
      /forum/forums/forum/discuss-simulation/electronics-2/
      All the best
      Erik
  • The topic ‘How to draw D,DD and DDQ coil for wireless charging in maxwell 3D as attaced pic?’ is closed to new replies.
