January 8, 2019 at 10:37 am
Jamessmp23
SubscriberHi, I would like to know how to draw and define non-merge line on the fluent mesher software [Q - meshing ANSYS AUTODYN PrepPost] ?
I tried to define the line in the middle section that I drew separately, but when I change it to 3D mode to go next step to the meshing procedure the line is auto merge.
Any advice ?Â
*When it's in the sketch mode you can see that the line is separate as picture 1.
I draw a geometry on the spaceclaim and use the fluent mesher.
Thank you,
Sumit
January 8, 2019 at 1:38 pm
Forum ModeratorWhen you do the extrude operation there's an option to Merge Topology - make sure that's set as No.Â
January 9, 2019 at 1:12 am
January 9, 2019 at 10:40 am
Forum ModeratorI thought you were using DesignModeler which behaves differently.Â
Having had a look the quickest way is to create the shape as you've done so. Use "split" under the Intersect panel and you should be able to split at the vertex.Â
January 14, 2019 at 2:04 am
Jamessmp23
Subscribersorry for late reply, it's works. Thank you for the advice.Â
- The topic ‘How to draw and define non-merge line on the fluent mesher software ?’ is closed to new replies.
5899
1306
