How to do Porous Media modelling for metal foam on PV Thermal System?
    • mattindrawijaya
      Hello, I am new to porous media modeling in ANSYS Fluent. Could anyone please explain the modeling of a metal foam as a porous media in a PV thermal (PV/T) system, starting from geometry creation, meshing, cell zone set up,and boundary conditions set up?
      I use the copper metal foam layered between copper absorber and PCM
      Thank you.
    • Essence
      For the starters, you can refer the following Ansys tutorial links.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v252/en/flu_tg/flu_tg_tut_catalytic_converter.html
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v252/en/flu_tg/flu_tg_tut_catalytic_converter_Topology.html
      • mattindrawijaya
        Hi, thank you for the help, but i have another problem that i can not open the links you gave me since i don't have the account number (customer number), is there any alternative for this solution? Thank you
      Try
      https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v252/en/flu_tg/flu_tg_tut_catalytic_converter.html
      https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v252/en/flu_tg/flu_tg_tut_catalytic_converter_Topology.html
