March 6, 2024 at 3:34 pm
swu321
SubscriberI want to have part of the structure do a constant value heat generation. This part is inside the structure (shown below).
Does anyone know how to select this part from the whole structure for heat generation?
I can see that there is a function option for 'Internal Heat Generation', but seems like I cannot manually input any function.
I feel like the most intuitive way is to define the self-heat region and select it in 'Internal Heat Generation', but I do not know how to do it.
Selecting the whole structure and use an expression to define the heat-generation part could be another intuitive way, but I do not know how to do it, either.Â
Really need some help????
March 7, 2024 at 3:10 pm
dlooman
Ansys EmployeeIt would be easiest and most accurate if you have geometry corresponding to the heated domain. Then you could make a named selection for that body and issue the command below in a commands object:
BFE,named_selection_name,HGEN,,10Â ! For a heat generation rate of 10
- The topic ‘How to do partial-volume heat generation?’ is closed to new replies.
