April 30, 2020 at 6:56 am
Swadesh
SubscriberHello Â
I am trying to simulate a circuit that has been designed using transistor. I have the spice model of the transistor and trying to do the nonlinear simulation. Can anyone please suggest which option I need to select in Ansys for nonlinear simulation?
or what is the procedure for non linear simulation with spice model?
The goal is I have the linear S parameter of a fixed bias condition and using the non linear model I would like to try the same bias condition and match the data. Later I want to try at arbitary bias condition based on transistor threshold KPIs. Thanks in advance.
May 15, 2020 at 8:43 am
rtk
Ansys EmployeeHello Swadesh,
What you are asking for seems like some kind of Amplifier or Oscillator. For such cases using Harmonic Balance solver would be preferred.
May 15, 2020 at 4:53 pm
Swadesh
SubscriberHello rtk,
Thank you for your reply. This is not amplifier or oscillator. Actually I want to use a transistor with metamaterial and measure performance at various bias condition. So for that case, should I go with HB simulation?
Thanks
Swadesh
- The topic ‘How to do nonlinear simulation in Ansys using spice model of active component?’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1338
1188
