how to do booliean operation in space claim
    • Shyam Prasad V Atri
      Hello
      I have a body like this and i am having really hard time splitting the body
      My objective is to subtract the cylinder from the cuboid
      I am trying to use split body and it is not allowing me to perform the operation
      What is the correct sequence to follow?
      1select cube
      2 select the two faces of cylinder (when i click control to pick second face the curser moves up)
      3 select the body to keep(many times the control does not go here) please tell me why?
      Is there any way to do the selection with the script..i am fed up of using this stupid space claim GUI. Its totally worthless and horrible to use..
    • ErKo
      Hi
      If you want to create a part (cube say) arround the blue/grey part you show then use enclosure:
      https://www.youtube.com/watch?v=2VFUHSc3_sg
      All the best
      Erik
      Hey i don't think you understood the question i have two questions (that youtube video is not helpful)
      question 1: is there a way to create a box and a curve with a defined set of points and do the subtract operation with script?
      question 2: When i created the box and selected the box and the curve why does it not split? This is the sequence i follow as per the one mentioned above
      look i figured a way to some how make it work on the GUI. Now i want to transilate it into a script of python and i am able to do so one or two bodies i am not able to repeat that
      # Python Script, API Version = V20
      # Intersect Bodies
      targets = Body1
      tools = Body2
      options = MakeSolidsOptions()
      result = Combine.Intersect(targets, tools, options, Info1)
      # EndBlock
      # Intersect Bodies
      targets = Body1
      tools = Body3
      result = Combine.Intersect(targets, tools, options, Info2)
      # EndBlock
      when i do tools=Body5 and do the process it does not work..when i look at the tree
      There is nothing called as body5 everything has a name called as component.. please tell me how to proceed is there a way i can list out all the bodies?
      a
      b
Viewing 6 reply threads
  • The topic ‘how to do booliean operation in space claim’ is closed to new replies.
