TAGGED: directional-coupler, interconnect, lumerical, s-parameters
July 19, 2021 at 1:52 pm
Love
SubscriberHello Lumerical Team,
I'm trying to configure a directional coupler with 70% of its power going to the PIN diode and 30% of power remaining in the loop. Is it possible to do that using s-parameters? Or there's a simpler way to do it? Thank you!
July 20, 2021 at 9:07 pmGWANG
Ansys EmployeeHi Love
You can use s-parameter to do this, and I think a directional coupler could also do the job, you just need to set the power split ratio to 7:3. The element is "Waveguide coupler".
July 21, 2021 at 12:47 pmJuly 21, 2021 at 5:34 pmGWANG
It's the coupling coefficient. The coupling coefficient is the field coupling ratio, so you will need to cacluate for the corresponding power spliting ratio to field spliting ratio.
Viewing 3 reply threads- The topic ‘How to distribute 70/30 power using s-parameters in INTERCONNECT’ is closed to new replies.
5654
1885
1404
1303
