July 20, 2024 at 4:50 pm
Appo Veini
SubscriberHello, for SpaceClaim 2024 R2 you can disable constraint based sketching in the Advanced options in the SpaceClaim Options (uncheck "Enable constraint based sketching"), but I don't see same option in Discovery 2024 R2 Settings, it is possible? Thanks.Â
Also there is few tutorial videos (for example on YouTube Ansys Chanel - Ansys Discovery Modeling Tutorial — Bike Crank Geometry — Lesson 4), where Constraints block is not present on the ribbon.
July 22, 2024 at 5:45 am
Keyur Kanade
Ansys EmployeePlease check  "Automatically Create Constraints" which is enabled by default when Constraint-based sketching is active.
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘How to disable Constraint Based Sketching in Discovery 2024 R2?’ is closed to new replies.
5649
1885
1404
1303
